OK here is my Guide to changing the color on the ZX12R LCD Display
Please bear with the pics the camera i borrowed doesn't do macro shots very well
i tried to cover all the aspects of the mod i have left out the stuff that i think doesn't
need explanation but i may have missed something if so let me know and i will gladly
update this guide
Tools And Supplies needed
Phillips Screw Driver
Hot Glue Gun
Soldering Iron,and Solder
Sand Paper for sanding and frosting LEDs
Small Heat Shrink Tubing
2 470 ohm 1/2W 5% Carbon Film Resistors
Radio Shack (Model: 271-1115 | Catalog #: 271-1115 )
4 Rectangular High-Brightness Blue LED Lamp
Radio Shack (Model: 276-013 | Catalog #: 276-013)
First Step remove the 6 screws and separate the back from the Speedo
then locate the 4 tabs that need to be bent to remove LCD Display
Once the LCD Display is removed you will find under the LCD an Orange Filter
Remove and discard then if your white reflector is damaged like mine flip it over so
the white side faces the LCD screen
The LEDs are a bit to long to fit well so you will need to sand them down shorter
and frost the ends. We need to do this so the light from the LEDS will defuse better
if you don't frost them the light will be very directional and you will see blue streaks
of light instead of a soft glow
Hot Glue the LEDs in Place that will give you a solid mount and be easier to bend the
leads to where you need them
flip over to the back of the Speedo and solder the resistors in and solder the grounds
from the LEDs
once thats done flip back over and solder the 2 leads for power together,and the other
end of the resistor that you have through the hole from the back
to the LEDs positive leads. Make sure the wire leads from power and ground don't touch!!
don't worry about them touching once separated we will cover them in hot glue later and
they will be fully insulated
At this point you can plug in the Speedo and test your setup is good all LEDs light
and the display is functional if everything works as it should you can now cover all
connection in hot glue front and back be sure to keep the mounting holes clear
as noted in pics
update this guide
Hot Glue Gun
from the LEDs
as noted in pics
