Chain slider guide replacement - Kawasaki Forum :: KawasakiWorld.com
post #1 of 4 Old 06-29-2016, 11:52 AM Thread Starter
Before I decide to replace the guide, does the swingarm pivot shaft have to be messed with. Can it be replaced by just removing sprocket cover ect.
I see that there's a oem type for 48 bucks but is there any other companies that offer them. Also semi stick on one's work with using the snap hole in the top of the arm.
4ftswells is offline
post #2 of 4 Old 06-30-2016, 02:47 AM
dave zx12r's Avatar
Garage
Ive seen them fitted but cant tell you where they are from. Anyone know?
dave zx12r is offline
post #3 of 4 Old 06-30-2016, 06:28 PM Thread Starter
Kawasaki parts nation has them but looks like a bitch to put it on.
post #4 of 4 Old 07-01-2016, 12:38 AM
dave zx12r's Avatar
Garage
Its not that hard to drop the swing arm down :-)
You can even leave the wheel on .
Just support bike from above by the rear footrests.
I use an engine crane, but a beam is just as good with a winch.
Leave back wheel touching floor to support weight , remove bolt and lift bike up / drop arm down . Loosen rear wheel and slacken chain and drop off the rear sprocket first and of course remove the lower fairing..Thats the easy way. The arms a lot easier with the wheel off :-) but dont you just hate refitting the back wheel on? I do!
Good luck :-)
Human Verification
Best Replacement Chain K Williams ZX-12R 14 10-21-2008 03:18 PM
Remember the worn chain slider thread? JL12 ZX-12R 0 12-02-2005 01:12 PM
Countershaft Sprocket Cover and Chain Guide OutsiderZX12R ZX-12R 3 11-15-2005 03:58 PM
chain slider pic,new vs worn r21xz ZX-12R 5 02-03-2005 02:37 AM
chain slider worn through ( pics ) r21xz ZX-12R 9 01-24-2005 11:07 PM
