brake system - Kawasaki Forum :: KawasakiWorld.com
post #1 of 17 Old 04-23-2016, 02:14 PM Thread Starter
antman25's Avatar
brake system
yesterday i went out and brought a vacuum bleeder to bleed the brakes. It will be a stiff brake the go soft. i changed the calipers. the brakes pads are new.i have been bleeding these brakes for the last 2hrs. I need HELP please.
antman25 is offline
post #2 of 17 Old 04-23-2016, 03:17 PM
MetalMagician's Avatar
Zip-tie your brake lever down overnight. This usually will let the air bubbles escape through the reservoir.
MetalMagician is offline
post #3 of 17 Old 04-23-2016, 03:28 PM
OutsiderZX12R's Avatar
Send a message via Yahoo to OutsiderZX12R
Agreed.
I hate stupid people.
OutsiderZX12R is offline
post #4 of 17 Old 04-23-2016, 03:30 PM Thread Starter
antman25's Avatar
do you think its the master cylinder is bad.
antman25 is offline
post #5 of 17 Old 04-23-2016, 03:59 PM
It could be. Try the zip-tie method. If you get a nice stiff lever and then it fades away back into mush I would guess that the master needs a rebuild. I might have a good master for a zx9 I would have to look though.
post #6 of 17 Old 04-23-2016, 06:31 PM Thread Starter
antman25's Avatar
So just take the cap off and zip tie the lever and that's it till the morning
antman25 is offline
post #7 of 17 Old 04-23-2016, 06:32 PM
I have never had to even remove the cap.
post #8 of 17 Old 04-23-2016, 06:37 PM Thread Starter
antman25's Avatar
ok thx
antman25 is offline
post #9 of 17 Old 04-23-2016, 11:54 PM
dastardly's Avatar
yep try the zip tie method I do mine on my 12 every few months just out of habit Craig
B1 black and "GOLD"
dastardly is online now
post #10 of 17 Old 04-24-2016, 06:29 AM
Tap calipers with rubberr mallet to help air trapped come to the top....be patinet it takes time
2002 Passion Red zx-12r
Flush mount signals,retrofitted projectors(yes I forgot demon eyes lol), indiglo gauges, under tail and integrated taillight,gear indicator,BMC race air filter, kleen air mod, scotts dampener,14r QAthrottle, advanced ignition,Full muzzy exhaust+PCV with autotune+bonneville box going for 200mph
wisniaPl is offline
post #11 of 17 Old 04-25-2016, 01:06 PM Thread Starter
antman25's Avatar
So I got up this morning to ride to work and as I was riding the brake went soft so
I guess it is the master cylinder
antman25 is offline
post #12 of 17 Old 04-27-2016, 01:14 PM Thread Starter
antman25's Avatar
so today i rebuilt my master cylinder and Im still getting a soft brake when im riding. its hard after bleeding then soft before i make it out the driveway
antman25 is offline
post #13 of 17 Old 04-27-2016, 03:57 PM
If you stop and pump it does the lever return? Sounds like warped rotors.
post #14 of 17 Old 04-28-2016, 11:47 AM Thread Starter
antman25's Avatar
Yes it does come back
antman25 is offline
post #15 of 17 Old 08-04-2016, 08:42 AM
I read your other post before this one so disregard that answer as I'm now going with the magician above as I had the exact same thing happen to me before and its actually the carriers that get warped rather than the rotors themselves, it pays to clean up the disc bobbins every few months to stop them seizing which causes this.
Hazzo is offline
Human Verification
04/05 12r/10r/6r complete front brake system ZuminaZX Classifieds 2 10-16-2014 12:02 PM
Brembo brake system/full nunukiii Classifieds 20 09-22-2009 06:44 AM
??? about wet system alcindus NOS and Turbo 10 07-13-2005 05:16 AM
CMC Brake Rotors from Brake Tech RobertinArgyle ZX-12R 5 03-31-2005 03:03 PM
