ZX-9R starting problems - Kawasaki Forum :: KawasakiWorld.com
post #1 of 6 Old 07-10-2013, 08:20 AM Thread Starter
Hi,
I have a 1999 ZX-9R which tipped over at pretty much a stand still. The bike ran after but a few days later will not start. Fuel pump is pumping fuel (as I have gas coming out when fuel line is pulled off) and the bike turns over but will not fire. Doesn't seem to be any gas smell coming from the tail pipe
Is there a tip over sensor on the 1999's?
Would a bad ignition, kill, Sidestand switch stop the fual flow or Ignition but still allow the bike to turn over?
Thank you for any help.
Jeff
jcolter is offline
post #2 of 6 Old 07-10-2013, 02:34 PM
ninjayorkie's Avatar
Garage
Cam position sensor top front of the number 1 cylinder. Gray plug above number one cylinder.
ninjayorkie is offline
post #3 of 6 Old 07-15-2013, 03:37 AM
Garage
Sorted or not?
post #4 of 6 Old 07-22-2013, 10:01 AM Thread Starter
ZX9r Starting issue
Ended up being the battery. It was only producing 6 volts.. I guess even with a jumper battery on it was screwing up the voltage enough the bike wasn't firing.
jcolter is offline
post #5 of 6 Old 07-23-2013, 02:34 AM
Garage
Normally when the battery voltage drops that low the starter lock out relay drops out and then you end up with the starter solenoid clicking away. You must have a good lock out relay which works at below 6 volts, some prefer 10 volts.
post #6 of 6 Old 07-23-2013, 10:55 PM
Member
Most of the swithes still allow to rev the starter. I had a 1993 zxr750r, and it was able to rotate even with the kill-switch off!!
Seems like no fuel entering the cylinders for me. Try changing fuel filter. Do you have an electric fuel pump?
I don't like to save, it's more fun to SPEND, \ If you like metal, you're my friend... - Manowar
Drink! Ride! LIVE!
Poodle44 is offline
Human Verification
Starting problems pop ZX-12R 12 03-10-2013 02:47 PM
Starting Problems busakillerzx12r ZX-12R 10 07-11-2009 03:26 AM
starting problems need some help or ideas zxdave ZX-12R 2 01-23-2006 08:22 PM
Starting Problems superninja12R ZX-12R 18 01-05-2006 03:21 PM
starting problems theinstag8r ZX-12R 3 03-23-2003 03:28 PM
