Front wheel replacement - Kawasaki Forum :: KawasakiWorld.com
post #1 of 12 Old 01-29-2012, 11:47 PM Thread Starter
First time to do this. kindly advice me what size of the allen wrench to dismantle the front tyre and the back/rear wheels. for me to get one from the store as im planning to dismantle and change the tyre at the same time to put the grease on the bearing... ill appreciate in advance your input gents.... thanks
marticio is offline
post #2 of 12 Old 01-30-2012, 05:23 AM
Renegade44's Avatar
17 mm
Renegade44 is offline
post #3 of 12 Old 01-30-2012, 07:17 PM Thread Starter
thanks mate..
marticio is offline
post #4 of 12 Old 02-05-2012, 11:52 PM Thread Starter
17mm for the left side if you sit on the Bike, im i right... how about on the right side. what is the size. visibly when i check , the size at the right side is bigger than the left side... which size i supposed to remove......
marticio is offline
post #5 of 12 Old 02-06-2012, 02:03 AM
drp
drp's Avatar
Garage
drp is offline
post #6 of 12 Old 02-10-2012, 09:33 PM Thread Starter
any one can advice what size of the hex fit to dismantle the right side axle when you sit on the bike. i try to used the other side of the spark plug socket as i watched it on the you tube...but it doesnt work,,,,its quit big than the hole of the axle. pls advice me the size....
marticio is offline
post #7 of 12 Old 02-10-2012, 10:31 PM
just did mine this evening with the backside of a craftsman spark plug socket. worked great.
tomstoys0 is offline
post #8 of 12 Old 02-11-2012, 01:21 AM Thread Starter
tom, I had purchased a set of socket wherein in include the spark plug socket, and when i tried it the back side, it doesnt work, its quit big....it doesnt insert on the axle head....on the left side its 17mm which i have it but i dont like to disturb this side coz its the nuts of the axle. pls advice what would be the next move to remove the axle.
marticio is offline
post #9 of 12 Old 02-11-2012, 02:08 AM
john02's Avatar
i have undone the axle from the 17mm side with no problems .or u can use the head of bolt with with with lock nuts on the big side
john02 is offline
post #10 of 12 Old 02-11-2012, 11:39 AM
kandypink12's Avatar
cheapest way out for one of the tools to do this with is lowes or home depot or ace hardware. just a bolt a few nuts and your in biz
kandypink12 is offline
post #11 of 12 Old 02-13-2012, 07:23 PM Thread Starter
anyone exactly can tell what the exact size of the hex or head nut ?
marticio is offline
post #12 of 12 Old 02-13-2012, 07:32 PM
john02's Avatar
buy one of these .from memory i think it's 22mm
Motion Pro - Superlight T-6 Hex Axle Tool 17,19,22,24 mm
john02 is offline
Human Verification
Front brake clunking and front wheel axle spacing DinoDanny ZX-12R 10 09-29-2013 02:01 PM
LED replacement for Front Running light? JPMuscle ZX-12R 23 06-17-2011 10:27 AM
need front replacement springs k9rockydog ZX-12R 8 06-03-2010 02:14 PM
help front tire replacement night rider ZX-9R 5 01-19-2004 05:20 PM
rear wheel bearing replacement "caution" Lou zx12r ZX-12R 24 10-09-2003 08:07 AM
