engine oil - Kawasaki Forum :: KawasakiWorld.com
post #1 of 8 Old 10-15-2010, 05:32 PM Thread Starter
Member
Location: lynnwood, washington, USA 20 miles north of Seattle
engine oil
what is the very best engine oil for the 2003 zx9r stock motor?
wdizard is offline
post #2 of 8 Old 10-16-2010, 05:55 AM
You buy oil for ambient temp reasons. If it's hot out, you run thick oil like 20w50. If it is cold out, you run 5w30.
Oil can be 30 years old sitting on a shelf or fresh out of a jiffy lube gun. Don't feed into the ads and all that BS.
hubz14 is offline
post #3 of 8 Old 10-16-2010, 02:27 PM Thread Starter
Member
Smile
Thank you so much.
Greg
wdizard is offline
post #4 of 8 Old 10-16-2010, 05:42 PM
KZScott's Avatar
Motul 300V
KZScott is offline
post #5 of 8 Old 10-16-2010, 07:23 PM
1990sss10's Avatar
Originally Posted by KZScott View Post
Motul 300V
2000 zx12 turbo, goofy redneck perched on top
1990sss10 is offline
post #6 of 8 Old 04-13-2012, 12:05 PM
DreamXXX's Avatar
Im using Repsol Full Synthetic 10W30 ...BUT, like Hubz14 said, on my next oil change with hot weather coming here im going to go to Repsol Full Synthetic 20W50
DreamXXX is offline
post #7 of 8 Old 04-14-2012, 12:10 PM
Member
blitzredux's Avatar
Bad information about oil is all over the place.
Read and understand viscosity before you decide (over the advice of the engineers that built your motor) to switch to something line 20W50.
I won't get into the oil argument but you should understand what running molasses in your motor means on a cold start. You are trying to help the motor when hot but killing it on each cold start. The idea that "thicker" is better doesn't hold water.
IMO 20W50 is yesterdays news and I would never run it in a bike of mine.
If you want to debate the oil thing, take into account that most modern turbo motors, that can run very hot run 0W40. Think about that and when you understand what the zero means you'll have a better understanding of whats bad and whats good.
Here is a place to start:
Motor Oil Viscosity Grades Explained in Layman's Terms
blitzredux is offline
post #8 of 8 Old 04-14-2012, 01:10 PM
my12r's Avatar
I used to run 20w50. Had all kinds of valve train noise. Had this mysterious "knocking" in the engine when hot. Engine itself seemed to heat up faster.
I switched back to 10w40, ALL of that stuff stopped! I will never put 20w50 in my bike ever again. Maybe if I buy an old air cooled something or other, I'll think on it, but this bike....nope. I've even tossed around 0w oil for a bit now, seeing as a few here have sang a few praises on it.
10w40 is bout as "thick" as you really want to go, imo....
T. J. Maiden ca. 1994
my12r is offline
Human Verification
need an engine for my zx-6r daone77 General Discussion 0 04-23-2011 05:02 PM
What engine will fit a H1 scotty37 ZX-7R 0 04-16-2009 05:55 PM
Difference European engine and American engine gebla ZX-12R 10 07-20-2006 10:02 PM
ENGINE ZX12HIGH ZX-12R 4 01-13-2005 03:06 PM
Engine Ice? HappyCamper ZX-12R 13 12-15-2004 07:06 PM
