gear questions please help - Kawasaki Forum :: KawasakiWorld.com
post #1 of 5 Old 03-01-2016, 05:42 PM Thread Starter
Question gear questions please help
hello everyone I'm new to any forms so please bear with me....I have a 2001 Kawasaki zx750r I bought the bike for 800 bucks its in good shape.
my question is this...... the bike isn't in running mode at this time do to cdi box I do have one on the way so it will not start.... I can put the bike in first gear by pushing down no prob. there and I can find natural but I cant get it to go in 2 ? any ideas on this ?
I was told that Kawasaki has a safety thing where it will not go to 2 with out it running is this true ? that the gears was made like this just in case you was on a slant or hill parking?
its my first bike...every other bike ive had dirt bikes that is you could shift all gears with out it running... can some body please help me understand....
also the N light doest come on its getting juice in the wires but the bulb dosent come on and the bulb is new tried 8 bulbs and nothing...im thinking something is wrong with transmission....someone please help
dumbdumb75 is offline
post #2 of 5 Old 03-01-2016, 06:49 PM
jhinderliter's Avatar
Sell it to me and get a modern fuel injected bike...
Send me pics and your price ... Jhinderliter@hotmail.com
Originally Posted by my12r View Post
He wishes he woulda thought of the green LED's first. He wishes he had balls big enough to ride without a helmet.
jhinderliter is offline
post #3 of 5 Old 03-02-2016, 12:26 AM
ninjayorkie's Avatar
Garage
The bike or at least rear wheel needs to be going round to enable you to select up into second. Its a kawasaki thing, maybe other makes too.
If you're getting 12 volts (battery voltage) at the push on connector to the neutral sensor, then the sensor is not working, or to much oil in the engine can some times cause the internal contact not to make.
You can unscrew the neutral sensor and check the little nipple on its end is slightly sprung loaded, and clean it.
ninjayorkie is offline
post #4 of 5 Old 03-02-2016, 03:03 AM
dastardly's Avatar
as ninjayorkie said its a kawasaki thing, positive neutral its a pain when you have to push start get it moving jump on then go up into required gear before dumping the clutch Craig
B1 black and "GOLD"
dastardly is offline
post #5 of 5 Old 03-04-2016, 05:24 AM
wylde's Avatar
or your linkage is upside down
" When In Doubt, There is No Doubt! "
wylde is offline
  Kawasaki Forum :: KawasakiWorld.com > Kawasaki Motorcycles > ZX-7R
Human Verification
low first gear turbo2112 ZX-12R 3 04-29-2013 01:14 AM
In gear and won't run DBZX12 ZX-12R 4 07-04-2006 11:23 AM
Tell me about 6th gear tozzi ZX-12R 74 01-17-2005 08:13 AM
