Turn Signal/Tail Light Problem - Kawasaki Forum :: KawasakiWorld.com
post #1 of 5 Old 07-29-2012, 03:52 AM Thread Starter
When I took my 1995 ZX7 for a ride, I noticed that the turn signals were not working correctly. Only the turn signals on the right hand side were work properly, and the left hand side front turn signal just lights up but does not blink and the back turn signal doesnít go on. I also noticed that the brake light does not work when pressing the front brake but works when pressing the back brake.
So far I check the bulbs in the turn signals and they are fine, then I checked the bulb socket and thatís good as well. The relay is good because there is current going through it but the orange wire has no current. I think itís the wiring, how can I check it and where does it lead to.
For the brake light, I have no idea what the problem could be.
Thanks
claudiomtl is offline
post #2 of 5 Old 07-31-2012, 09:59 AM
Send a message via Yahoo to ZXLNT
Check the rear brake light switch..
ZXLNT is offline
post #3 of 5 Old 01-31-2013, 08:44 PM
check the front break wiring or switch connection.
_______________________________________
triumph motorcycles for sale
donaldlgage is offline
post #4 of 5 Old 01-31-2013, 09:53 PM
joker14n's Avatar
Send a message via Yahoo to joker14n
Just gotta love the oddball electrical ,problem...one of the true joys of motorcycles. Whenever I run into these kind of issues, I start with the obvious stuff. Disconnect all the plugs for the components in question. Clean the connections with electrical contact cleaner, then squirt some dielectric grease into the sockets and re-assemble. Also keep an eye open for any bad grounds you may encounter along the way.
joker14n is offline
post #5 of 5 Old 02-01-2013, 04:47 PM
my12r's Avatar
Check for a bad bulb.
T. J. Maiden ca. 1994
my12r is offline
  Kawasaki Forum :: KawasakiWorld.com > Kawasaki Motorcycles > ZX-7R
Tags
tail light, turn signals
Human Verification
Turn signal problem! John08 ZX-12R 2 06-23-2012 09:46 AM
ZX12 Rear Brake light tail signal integrator thing shiphteey Classifieds 2 06-22-2009 08:18 PM
UFO LED integrated tail light/turn signal assembly RobertinArgyle ZX-12R 0 08-24-2006 06:32 AM
turn signal problem myzen ZX-9R 3 01-04-2004 06:17 PM
