98 zx6r rear brake problem - Kawasaki Forum :: KawasakiWorld.com
post #1 of 1 Old 10-11-2016, 11:38 PM Thread Starter
I just changed pads today and noticed a O-ring twisted op inside.
After pushing the piston out to set it I noticed it was stretched and needs to be replaced. For now I just removed it because it is not leaking or anything but now after bleeding the brakes and taking a test ride I noticed it feels like it is dragging and when i press the brake petal I have nothing in the back. The caliper piston did look pretty bad but what I would like to know is should I try rebuilding the master and caliper or just replace it?
PS even with the brake line off and bleeder valve out I had a rough time compressing the piston. Could it be that it is stuck? What are your thoughts on this?
Noob owner of 98 zx6r project bike.
zaden is offline
  Kawasaki Forum :: KawasakiWorld.com > Kawasaki Motorcycles > ZX-6R
Human Verification
ZZR1400 Rear Shock Compatibility chris555k ZX-14 0 10-10-2016 02:09 PM
Rear brake Savagerider ZX-12R 0 09-17-2016 11:17 AM
Vulcan 2000 valve train noise pimcrd Vulcan 17 09-10-2016 03:36 PM
Wanted rear brake caliper Savagerider Classifieds 1 09-07-2016 02:17 PM
Venhill front brake lines BigSkip765 ZX-12R 0 07-22-2016 11:42 AM
