02 zx6r front fairing loose!! Plz help - Kawasaki Forum :: KawasakiWorld.com
post #1 of 4 Old 02-22-2015, 07:55 PM Thread Starter
The front end on my 02 zx6r is loose..when I go over bumps the whole fairing moves..I can tell because the light from the headlights move around a lot on the road at night and the black support bar also moves over bumps......
Mikezx6r is offline
post #2 of 4 Old 02-22-2015, 08:11 PM
Send a message via Yahoo to ZXLNT
Tighten the bolts down
ZXLNT is offline
post #3 of 4 Old 02-22-2015, 09:07 PM
KwakRider's Avatar
Garage
Commom occurance...check the 2 main fairing stay bolts....the black support bar as you call it!
KwakRider is offline
post #4 of 4 Old 03-10-2015, 02:39 AM
joehd8811's Avatar
The most efficient way to check, basically is to remove the entire front fairing. Not hard to do, but can take a little patience. There is an upper stay bracket if you wanna call it that. Make sure that is all in tact not cracked, check for loose screws. Inspect the fairing for cracks etc. And reinstall making sure everything is tight. It seems to be regular problem on these ZX6Rs
If you are not living on the edge, you are taking up too much room
joehd8811 is offline
  Kawasaki Forum :: KawasakiWorld.com > Kawasaki Motorcycles > ZX-6R
Human Verification
Loose, shaking front end... South Jersey zx ZX-12R 12 03-31-2013 05:27 PM
1993 ZXR750 Front brake disc rotor loose ILiveForRiding ZX-7R 1 07-20-2012 10:54 AM
WTB - 03 ZX12 Front Fairing Future553 Classifieds 1 05-22-2010 05:54 PM
Right side fairing and front fairing?????? idahorider1 ZX-12R 14 08-31-2006 05:21 PM
front end feels loose alcindus ZX-12R 3 08-18-2004 09:06 PM
