Oil light flickering - Kawasaki Forum :: KawasakiWorld.com
post #1 of 5 Old 06-06-2016, 10:01 AM Thread Starter
Help!!! I have a 2009 Kawasaki Ninja ZX-14. Yesterday I was riding for about an hour and half. On my way home my oil warning light came on. I let off on the throttle and light went off. Then it would flicker. More throttle light would come on. I have not changed oil lately. Which I read most threads talk about burping. Don't think thats a problem. I also noticed the horn was not working. I was worried about no oil in motor. So I dropped a quart of oil into the motor. I was out in the Texas hill country so I did not want to damage the motor. I got home riding very slowly trying to keep light off. It continued to flicker. going off and coming on bright. Once I got home I thought maybe the horn was stuck so I tapped it with a wrench lightly. Now the horn works but oil light still flickers. I think I may have either added too much oil or maybe it needs more. Or maybe electrical. This bike has been an awesome bike with no troubles. Sitting on kickstand no oil shows in window. When bike sits up straight it goes up to line and maybe even more. I am thinking that extra quart should not have been added. But I would think if I over filled it I would be able to see when on kickstand the window might show 1/4 or 1/2 full meaning I over filled. Motor never sounded any different. No ticking like short of oil. All the other threads I have read deal with just adding oil or oil change and burping. Don't think this is my issue. Please help!!!!
DAQUARISDJMUSIC is offline
post #2 of 5 Old 06-06-2016, 10:32 AM
Member
JGIG73's Avatar
I always fill my oil to the top line on the sightglass. When on the stand, you wont see oil in the sightglass, you have to have the bike upright and on a level surface. Im at 15K miles and have always filled to the top line. Full synthetic every 2000 miles. Almost sounds like an electrical issue.
JGIG73 is offline
post #3 of 5 Old 06-06-2016, 01:50 PM
Send a message via AIM to Lou zx12r
The light usually lights if pressure is low do to lack of oil or a bad sensor. Maybe it's coincidence that the horn stopped working around the same time, maybe not. As stated above, I also keep my oil level at the top mark of the sight glass. I pre fill the filter but this isn't your issue. I would place the bike on level ground, straight up and down and check the oil level, adjust as necessary. If still flickers look into sensor or wiring issues.
Lou
2012 zx14r
2009 Concours 14
2000 zx12r
One day at a Time!!
Lou zx12r is offline
post #4 of 5 Old 06-06-2016, 02:50 PM
hagrid's Avatar
You have an electrical issue.
hagrid is offline
post #5 of 5 Old 08-06-2016, 02:46 AM
If you added a qt of oil to it and it only came up to the bottom line when the bike is upright you are very low on oil. When was the last time you changed it? What oil you got in it? What filter? You still might have a electrical issue but something doesn't sound right with the oil amount. I have had a couple of k and n and two of the new china filters from kawi not seal like they should and dripped oil for a bit until I noticed it on my weekly chain maintenance. Redsled.
redsled is offline
  Kawasaki Forum :: KawasakiWorld.com > Kawasaki Motorcycles > ZX-14
Human Verification
Neutral light flickering...? Busabuser ZX-12R 5 06-05-2015 11:56 PM
Lights Flickering RossTrue ZX-12R 4 08-02-2013 06:02 PM
Oil light flickering Fifty6 ZX-12R 4 03-02-2013 05:57 PM
oil lite flickering jragates ZX-12R 4 07-02-2012 01:24 PM
Lights in gauge panel are flickering? Anyone else experience Rizzo ZX-12R 3 04-28-2004 06:18 PM
