Brake drag help - Kawasaki Forum :: KawasakiWorld.com
post #1 of 3 Old 10-14-2015, 06:52 AM Thread Starter
Member
JGIG73's Avatar
Brake drag help
Wanted to know if you guys are getting a small amount of drag on your front and rear brakes. Yesterday I did a front caliper cleaning (without removing the pistons and seals) scrubbed everything down with Palmolive dish soap worked the pistons in and out of the calipers and re assembled. With the front wheel off the ground the tire spins however I can hear a very quiet amount of drag and it slows the wheel down. Its not a drastic slow down but its evident. Took the bike to work today and braking was very good, with a linear feeling. Drove 20 miles and parked the bike, immediately I touched both front rotors and they where only slighty warm. The rear rotor however was hot. To the point where I couldnt keep my hand on it. The rear rotor isnt discolored or warped, but its getting hot from a small amount of drag. Could this be a sign of the seals needing to be replaced as they are not allowing the pistons to fully retract into the calipers, or is it normal to have a fair bit of drag on the front and back. My fluid levels are not over filled in the reservoirs.
JGIG73 is offline
post #2 of 3 Old 10-14-2015, 09:20 AM
jhinderliter's Avatar
Do they pulse ?
Originally Posted by my12r View Post
He wishes he woulda thought of the green LED's first. He wishes he had balls big enough to ride without a helmet.
jhinderliter is offline
post #3 of 3 Old 10-14-2015, 02:43 PM Thread Starter
Member
JGIG73's Avatar
No pulsing. After the cleaning and reassemble, the fronts are better than ever. Its just a heat issue on the rear. I just got done cleaning and re assembling the rear Ill test it again tomorrow. It was pretty filthy, maybe the pistons are just not able to retract well cus of all the brake dust and dirt.
JGIG73 is offline
  Kawasaki Forum :: KawasakiWorld.com > Kawasaki Motorcycles > ZX-14
Human Verification
brake drag KZScott ZX-12R 8 07-23-2010 06:25 AM
Sprockets for nos/drag XXORCIST Racing 1 03-14-2006 12:14 PM
CMC Brake Rotors from Brake Tech RobertinArgyle ZX-12R 5 03-31-2005 03:03 PM
Front Brake Drag? ZX-12R 7 09-15-2002 12:00 PM
