What zx14 parts fit on 01 zx12 - Kawasaki Forum :: KawasakiWorld.com
post #1 of 11 Old 05-15-2017, 12:01 PM Thread Starter
Need some rotors and a master cylinder my 01 zx12. Will a zx14 rotors bolt on to the stock wheels. Will the 14 master cylinder be a better upgrade to two steel braided lines
BigSkip765 is offline
post #2 of 11 Old 05-15-2017, 01:29 PM
MetalMagician's Avatar
Brake rotors are a no go. The master is a huge upgrade for the 12. You have to use the 14 lever. You may have clearance issues at full turn and you have to be creative with mounting the reservoir. If you are interested I have good used rotors I'd let go cheap as I have no use for them.
MetalMagician is offline
post #3 of 11 Old 05-15-2017, 04:48 PM Thread Starter
You got pics of em and are they good better question is can 14 front rotors fit
post #4 of 11 Old 05-16-2017, 12:45 PM
Zx14 front rotors will not fit. Larger center bore, different bolt pattern and wrong offset. I have 3 sets of good front zx12 rotors. Are you certain that your rotors are bad? I noticed you have several threads about front brakes. Your problem could be with other components.
post #5 of 11 Old 05-16-2017, 05:42 PM Thread Starter
To be honest i dont know when i pull the lever in its a smooth stop...but its very soft i have Venhill braided lines on the stock MC and i know its supposed to be tighter than that
post #6 of 11 Old 05-16-2017, 05:42 PM Thread Starter
The shop rebled everything too and they're tryna get me to go back to the stock lines
post #7 of 11 Old 05-16-2017, 06:00 PM
The lines wouldn't give you a soft lever (might want to find a new shop). The stock brakes are a pain to fully bleed. Does it get stiff if you pump it? If so does it fade over time while parked? Try to zip-tie the lever down and leave it sit overnight.
post #8 of 11 Old 05-16-2017, 06:24 PM
Crack the banjo bolt at the master. Make sure no air there. Then bleed the longest line at the caliper. . Then the short line at the caliper.
color me gone is offline
post #9 of 11 Old 05-17-2017, 05:55 PM
KZScott's Avatar
this^^^^^^^^^^^
sometimes no matter how much fluid you pump through it, you wont get all the air out unless you start at the master banjo. some even have a bleed screw here, but the ones that dont, just crack the bolt and bleed it that way.
also if the shop wants stock lines over braided, go somewhere else
KZScott is offline
post #10 of 11 Old 05-18-2017, 06:02 PM Thread Starter
Everything yall saying ive done the shop rebled everything and i still have to pump the lever...so it could be a bad mc or bad seals or rotors
post #11 of 11 Old 05-18-2017, 06:44 PM
dastardly's Avatar
on the zip tie I do this every 6 months or so and it feels better after good luck Craig
B1 black and "GOLD"
dastardly is offline
Human Verification
2004 ZX 12 Parts for sale JeffM ZX-12R 0 12-27-2016 07:05 AM
2004 ZX12 parting out see list below JeffM Classifieds 16 10-23-2016 10:10 AM
Another ZX12 nbr1stunna ZX-12R 24 10-21-2016 07:11 PM
Zx14 shock on zx12 BigSkip765 ZX-12R 1 10-19-2016 09:19 AM
Turbo ZX12 mini-resto 1990sss10 ZX-12R 12 08-23-2016 03:24 AM
