Fuel pump not priming after replacing stator - Kawasaki Forum :: KawasakiWorld.com
post #1 of 6 Old 04-19-2017, 10:19 AM Thread Starter
QDL62's Avatar
Garage
Stator burnt out, so replaced it. The bike started with old stator but wires got hot. now I have replaced stator I turn on ignition all lights on dash working ok neddles move and reset as it should but now the bike will not start. I cant here the pump priming (little wizzy noise when you turn on ignition. I checked the regulator and it appears ok but have ordered a new one anyway. Any ideas.....
QDL62 is offline
post #2 of 6 Old 04-19-2017, 01:51 PM
dastardly's Avatar
Hi QGL62 check all the fuses hope its an easy fix Craig
B1 black and "GOLD"
dastardly is offline
post #3 of 6 Old 04-20-2017, 01:12 AM Thread Starter
QDL62's Avatar
Garage
All fuses are good. Thought it might be datatool alarm so linked it out but it is not that. Spent a whole day checking all the plugs n sockets to see if I had disturbed one when installing stator cable and cant find any that were open.
QDL62 is offline
post #4 of 6 Old 04-20-2017, 02:01 AM
ninjayorkie's Avatar
Garage
You don't say which model you have, as there are wiring differences, but the guides on the zx9 site are more or less the same switches. ok, Your garage picture shows an A1 so the zx9 wirings the same. if you cant see the pictures click on the place holder.
Clutch lever switch, try starting with clutch lever pulled in.
Kill Switch or start button dirty contacts.
Clutch switch checking and cleaning zx-9r.net ? View topic - Clutch switch checking, cleaning and/or replacing.
Kill Switch Start button cleaning zx-9r.net ? View topic - How to strip and clean the start button and kill switch.
ninjayorkie is offline
post #5 of 6 Old 04-20-2017, 04:08 AM
dastardly's Avatar
yeah Im with ninjayorkie check the clutch switch, not sure how it effects pump, but if the switch is not working try starting in N out of gear don't touch the clutch and see if it works Craig
B1 black and "GOLD"
post #6 of 6 Old 04-20-2017, 07:35 AM Thread Starter
QDL62's Avatar
Garage
Sorry forgot to mention it was a n A1. Many thanks for the advice been at Oulton Park watching BSB testing so will try these things tomorrow and lwet you know how I got on. I say the strange thing is that I changed the stator in a day and it started with old knackered one and was mortified when after putting new one in it would not start. But I will post the result of work tomorrow.
QDL62 is offline
Human Verification
Fuel pump. seanszx12r ZX-12R 3 04-27-2017 11:39 AM
2000 ZX12R - Electrical Gremlins (maybe ECU) SuperHoon ZX-12R 1 12-19-2016 06:21 AM
Fuel pump ,again !! re-dynoed andy1965 ZX-12R 10 09-25-2016 11:41 AM
2004 Zx12r fuel pump not priming help Resact ZX-12R 4 09-06-2016 02:01 PM
fuel pump and lines question WwDestiny ZX-9R 0 08-05-2016 01:33 PM
