Fuel pump. - Kawasaki Forum :: KawasakiWorld.com
post #1 of 4 Old 04-19-2017, 09:34 AM Thread Starter
seanszx12r's Avatar
Fuel pump.
I'm curious to know if there is a better performing fuel pump for these ZX 12's (mines a 04 with 50k on it) than the stock ones. I've gone through two OEM's and didn't know if there is a more reliable pump available or maybe the fact that I reside in Az and with it's summer weather could be a factor in the life of the pump. Any recommendations would be helpful. Thanks
seanszx12r is offline
post #2 of 4 Old 04-19-2017, 01:55 PM
dastardly's Avatar
Hi seanazx12r its not normal for the pump to fail, its usually the filter that blocks up, in your year mod the filter is in the pump housing, get rid of it install an inline filter and you are good to go, there are some wright ups on this forum about what to do good luck Craig
B1 black and "GOLD"
dastardly is offline
post #3 of 4 Old 04-20-2017, 12:45 AM
dave zx12r's Avatar
Garage
Walbro in tank is an easy and inexpensive upgrade.
Several models will do the job. There's always plenty on Flea-Bay.
dave zx12r is offline
post #4 of 4 Old 04-27-2017, 11:39 AM Thread Starter
seanszx12r's Avatar
Thanks Dave.
Human Verification
2000 ZX12R - Electrical Gremlins (maybe ECU) SuperHoon ZX-12R 1 12-19-2016 06:21 AM
Squashed fuel return pipe !! andy1965 ZX-12R 34 12-07-2016 11:21 AM
Fuel pump ,again !! re-dynoed andy1965 ZX-12R 10 09-25-2016 11:41 AM
2004 Zx12r fuel pump not priming help Resact ZX-12R 4 09-06-2016 02:01 PM
fuel pump and lines question WwDestiny ZX-9R 0 08-05-2016 01:33 PM
