Front brake help please - Kawasaki Forum :: KawasakiWorld.com
 1Likes
  • 1 Post By dastardly
post #1 of 6 Old 04-02-2017, 10:32 AM Thread Starter
Idk if im doing something wrong but pumping the front brake to put new fluid in the front brake isn't working for some reason i need some help. I know for the banjo bolt its a washer brake line washer brake line washer for the mastercylinder. Washer brake line and washer for each of the calibers
BigSkip765 is offline
post #2 of 6 Old 04-02-2017, 11:06 AM
Mauser's Avatar
Either side of every banjo fitting should be a copper washer...?, connect some clear hose to bleed nipple and undo the bolt 1/2 turn ideally I place a ring spanner on the nipple first then the hose so you can easily open and close the nipple....then just top up the reservoir and start pumping the lever with the nipple open, you should see either a single air bubble or maybe just a rise in fluid level coming from the small hole in the reservoir which lets fluid into the cylinder...takes time but after 5 mins the fluid level should start dropping...top up as required. Once it starts coming through the hose you can then close the nipple and see if things start to firm up, then its just a matter of time opening the nipple whilst pulling the lever back then closing it before releasing it...so your displacing the air with fluid.
*** ZX12-R ~ XJR1300SP ~ XR650R ~ DT175MX ***
Mauser is offline
post #3 of 6 Old 04-02-2017, 11:32 AM Thread Starter
Every washer is copper i pumped the lever for almost 2 hours so i zipped tied the lever to the handle bar and opened the bleeders
post #4 of 6 Old 04-02-2017, 12:39 PM
dastardly's Avatar
un do your bleed nipples and make sure they are clean and clear for fluid to flow through, its no good just pumping the lever as your system will be full of air, you need to do this as others have said ("1" bleed nipple with clear hose on it in a jar submersed in brake fluid with ring spanner on nipple "2" with the lever pulled in crack the bleed nipple a 1/2 turn air or fluid will flow into hose shut off the nipple all while holding the lever in "3" pump a few times and hold in again and crack nipple as step 2 you need to do this to replace the air with fluid by just pumping the lever you are just compressing the air in the line when you let the lever go the air pushes the fluid back into the reserveoir look at youtube vids on bleeding and good luck craig
B1 black and "GOLD"
dastardly is offline
post #5 of 6 Old 04-02-2017, 12:52 PM
dastardly's Avatar
Just re read my post it sounds a little abrupt sorry not my intention Craig
B1 black and "GOLD"
post #6 of 6 Old 04-02-2017, 01:04 PM
dastardly's Avatar
I have used a syringe full of fluid attached to the bleed nipple using clear hose crack the nipple and push the fluid and air up through into the MC you need to do this for both callipers good luck and check out those youtube vids they are really helpful Craig
ciderking likes this.
B1 black and "GOLD"
Human Verification
changing brake line need opinion 50yroldzx12r ZX-12R 5 03-17-2017 08:08 AM
rim swap zx12r zx12rRider ZX-12R 0 01-10-2017 02:22 PM
front brake discs replacements robstar Z750 Z1000 0 11-25-2016 11:49 AM
Vulcan 2000 valve train noise pimcrd Vulcan 17 09-10-2016 02:36 PM
Venhill front brake lines BigSkip765 ZX-12R 0 07-22-2016 10:42 AM
