Top speed problem - Kawasaki Forum :: KawasakiWorld.com
post #1 of 8 Old 11-15-2016, 08:34 PM Thread Starter
Top speed problem
So I rode the bike on highway today first time in a while. I noticed that hammering in firat gear I'm only getting 65mph. I'm wondering what the reason could be it seems like all gears I'm not getting the speed I use to. It was a cool night 50 °F, my tire may not be the best feels a little slick but I'm not sure if wither would lower everything that much
Savagerider is offline
post #2 of 8 Old 11-15-2016, 10:09 PM
drp
drp's Avatar
Garage
What rpm is the engine running at when riding at speed.
Clutch slip !!!!!
drp is offline
post #3 of 8 Old 11-16-2016, 03:05 AM Thread Starter
It doesn't really feel like it's slipping. When taking off I feel that back tire even spin out a little. I also forgot to mention I recently got aftermarket rims. I told them I want same sprocket.
post #4 of 8 Old 11-16-2016, 03:26 AM Thread Starter
So I hooked gps up and took it to highway and the gps is saying that my speedometer is reading 10 to 12 higher than I'm actually going when at steady speeds. So when I am going 70 on gps my speedometer is showing 80 to 82. Could they have put a different sprocket on and that be reason I'm not getting the top speed in gears I use to. Top speed 65 mph or so in first
post #5 of 8 Old 11-16-2016, 05:52 AM
my12r's Avatar
Count the teeth. Should get 87mph in first with stock gearing. My speedo was off about 5mph or so when I was using the 17 toofer. I put the stock 18 toofer back on after about 200 miles. Cost of gas vs the minimal performance gain was crazy. Dropped to about 19~20mpg from almost 40. Course some of that might have been a heavy wrist tho...
T. J. Maiden ca. 1994
my12r is offline
post #6 of 8 Old 11-16-2016, 09:25 AM Thread Starter
The front sprocket is stock I counted the back and it's 46
post #7 of 8 Old 11-17-2016, 11:09 AM
my12r's Avatar
Somethin fishy goin on. Stock gearing shohld get you to an indicated 87mph. You say you got stock gearing and the speedo is how far off? 10~12mph....interesting....
my12r is offline
post #8 of 8 Old 11-18-2016, 10:32 PM Thread Starter
After some looking I noticed my speedometer was not starting at 0 it was starting at around 10. Couple cycles from turning key all was fixed. Now the speed issue. I realized gps wasnt keeping up with acceleration so I kept it in first hi rpm longer and was showing around 78 to 80 mph.right before redline. Is this about right?
Human Verification
Disappionting top speed. smiffy ZX-12R 24 12-10-2016 06:10 AM
ZX12R sidewinder problem rtracing ZX-12R 4 11-14-2016 01:08 PM
Starting problem rwb2356 Vulcan 2 10-18-2016 05:40 AM
98 zx6r rear brake problem zaden ZX-6R 0 10-11-2016 10:38 PM
1998 vn1500 classic problem gollum Vulcan 1 08-08-2016 08:17 PM
