Does anyone know about a gear shift sensor on a 01 zx12 - Kawasaki Forum :: KawasakiWorld.com
post #1 of 11 Old 09-20-2016, 09:15 AM Thread Starter
I got a 01 zx12 just last night i was right the neutral indcator stop showing on the dash. So i was told uplug the connectors on the kick stand and it came back on but i dont want to keeping doing that. The shop said its a gear shift sensor can some send pics of it ir just help in the process thanks all
BigSkip765 is offline
post #2 of 11 Old 09-20-2016, 04:32 PM
SteveW's Avatar
Mine does it all the time, I've just learnt to live with it. I've even put in a new spring and contactor behind the sensor and it still does it when it warms up..
2006 ZX-12R B6F
SteveW is offline
post #3 of 11 Old 09-20-2016, 05:55 PM Thread Starter
So have you thought of replacing it
post #4 of 11 Old 09-21-2016, 04:40 AM
SteveW's Avatar
Yeah, but hasnt bothered me that much.. New cost too much, cant really find one with low KM either
2006 ZX-12R B6F
SteveW is offline
post #5 of 11 Old 09-21-2016, 07:37 AM Thread Starter
What are some steps i can take to make sure it come back on. I ask that because with the clutch engaged the bike doesn't want to start unless its in neutral
post #6 of 11 Old 09-21-2016, 08:58 AM
ninjayorkie's Avatar
Garage
You probably want to be doing some clutch switch checking, this is for a zx9 but its the same system. zx-9r.net :: View topic - Clutch switch checking, cleaning and/or replacing.
Part number for a new one 27010-1094 $22 it's used on loads of kawasaki bikes.
ninjayorkie is offline
post #7 of 11 Old 09-21-2016, 01:02 PM
MetalMagician's Avatar
My A model does this intermittently too. Sometimes it will start and won't be able to idle while on side stand because it thinks it's in gear. Other than that it all works as should you just have to remember if you're in neutral. It really doesn't bother me enough to want to replace it.
MetalMagician is online now
post #8 of 11 Old 09-21-2016, 03:28 PM
SteveW's Avatar
Yeah, I'd look into Yorkie's info about the clutch switch also having an issue
2006 ZX-12R B6F
SteveW is offline
post #9 of 11 Old 09-21-2016, 03:44 PM Thread Starter
Okay were would the clutch switch be underneath the tank and i got someone who has spare sensors from a running 12
post #10 of 11 Old 09-21-2016, 03:52 PM
SteveW's Avatar
Have a read of the zx9 forum link Yorkie posted
2006 ZX-12R B6F
SteveW is offline
post #11 of 11 Old 09-25-2016, 01:22 PM
Member
Redrider2k2's Avatar
My neutral light was intermittent for a while also. It was mostly just annoying. It wouldn't come on at initial start up so it would force you to pick it up off the side stand and then, once running, it would light up again and you could set it back on it's stand. I thought about fixing it but then it pitched the #3 connecting rod through the case...Suddenly wasn't so important anymore
Redrider2k2 is offline
Human Verification
2004 ZX12 parting out see list below JeffM Classifieds 16 10-23-2016 10:10 AM
reverse shift, how i did it with QS lyhneDk ZX-12R 8 09-18-2016 04:49 AM
Turbo ZX12 mini-resto 1990sss10 ZX-12R 12 08-23-2016 03:24 AM
