ZX12R stator coil or rectifier problems? - Kawasaki Forum :: KawasakiWorld.com
post #1 of 3 Old 09-05-2016, 04:54 AM Thread Starter
Unhappy ZX12R stator coil or rectifier problems?
Hi.
Is there anyone who can help me if my bike is okay, or just on the way down?
It started with a melted plug between the stator coil and the rectifier!
I just connected the wires (without a plug) and started testing according to the manual.
The stator resistance is about 1,2 ohm measured on a 0-400 ohm instrument on all 3 circuits.
The output from the stators is about 78 VAC on all 3 circuits (open circuit and around 4000 rpm), and the output from the stators is about 12,5 VAC on all 3 circuits (closed circuit and around 4000 rpm) when the rectifier is connected.
I think the wires and the rectifier turns hot while running, but I dont know how hot it normally should be?
I havent measured the power from the rectifier yet, but does anyone know if this is normal, or is it the stator coil or rectifier which is about to be broken?
Anyone who can help?
Lejfi23 is offline
post #2 of 3 Old 09-05-2016, 05:27 AM
ninjayorkie's Avatar
Garage
Do some regulator diode checks as I've seen them give out 13+ volts and still have a bad diode, which does make everything work harder.
Regulators do get quite hot anyway.
ninjayorkie is offline
post #3 of 3 Old 09-05-2016, 11:55 PM Thread Starter
Thanks, I will try to measure that.
Lejfi23 is offline
Tags
coils, melted plug, rectifier, stator
Human Verification
FT: ZX12R leather jacket 2XL bldragon Classifieds 1 09-10-2016 02:40 PM
2000-2001 ZX12r Motor Needed maldridge403 ZX-12R 1 08-09-2016 07:57 PM
