Tire change/Engine noise
This is a discussion on Tire change/Engine noise within the ZX-12R forums, part of the Kawasaki Motorcycles category; Well we had a nice sunny 55 degree day today here in PA and I happened to be home from the weekend from college, so ...
| | LinkBack | Thread Tools | Display Modes |
| | #1 |
| Junior Member From: Harrisburg, PA Joined: Jun 2011 I Ride: ZX-12R Posts: 14 | Tire change/Engine noise
Well we had a nice sunny 55 degree day today here in PA and I happened to be home from the weekend from college, so I figured it would be a good chance to get the old 12 out of hibernation and change the front tire to the new Michelle PR2 I got for Christmas. To make an incredibly long story short, essentially everything that could go wrong did, including the 12 falling off of the stand (must have still been sleepy ) . It did not fall very hard as I managed to catch it as it was falling but because of my position I couldnt hold it up. Now when it runs I notice a loud ticking coming from the top right side of the engine, when revved the ticking speeds up proportionately although it doesn't seem to get any louder. Any suggestions, or am I just paranoid?
| | #2 |
tweak the fan maybe?
| | #3 |
if the noise increases as you rev it up, it only makes sense (to me), it's coming from the engine!
| | #4 |
| Senior Member From: Hardwick, just past nowhere Joined: Jul 2008 I Ride: '03 ZX12R; '00 883 Sportster; '83 GS750T Posts: 105 |
Fell on the right side? A description of any damage might help. How about the exhaust? Leaking anywhere since the fall?
| | #5 |
I thought it could be that but the fans werent running at the time. ![]() |
| | #6 |
Ticking noise when cold and goes away when warmed up possible valve clearance.If the bike has been sitting on the side stand for a long period of time lack of oil,,
| | #7 |
| | #8 |
| Junior Member From: Harrisburg, PA Joined: Jun 2011 I Ride: ZX-12R Posts: 14 | |
| | #9 |
| Senior Member From: Hackettstown N.J. Joined: Jan 2008 Posts: 301 |
Just a stupid question, does your oil light come on with the key and go right out when you start the engine? ZX12s don't like being on their side and suck air into the oil pickups causing a lack of oil pressure. If your oil pressure light is working correctly, this is not the issue.
| | #10 |
exaust leak... tighten up the nuts on your exaust studs coming out of the head... | |
| | #11 |
| | #12 |
| Senior Member From: CA Joined: Feb 2009 Posts: 1,554 |
Bike's been sitting? Start up a dry engine without priming that oil filter? Top end tick sounds like no oil getting there.
| | #13 | |
| Junior Member From: Harrisburg, PA Joined: Jun 2011 I Ride: ZX-12R Posts: 14 | Quote:
![]() Thanks to everyone for the help! | |
| | #14 |
Before you spend any money, try this - ENGINE COLD! 1) Bump your starter a couple of times without starting the motor, just a short bump. 2 Loosen the two bolts at the top and the bottom of the cam chain tensioner from a quarter of a turn to a third of a turn. Do not go further or else you will have to remove and reset the tensioner. 3) Lightly tap on the bolt in the center a wrench or hammer 4) Retighten the two end bolts. Start your motor. The noise should be completely and immediately gone. I've done this on a '85 Ninja, a '90 ZX11, and two ZX12s. Simple and effective. Cam chains are good for making a noise that rises and falls with engine speed, and gets quieter as the engine warms. Good luck with it.... | |
| | #15 |
I like suggestions that take require no money lol. Would it make any difference if the cam chain tensioner wasn't stock? I believe it's an APE, not 100% on that but I'm definitely sure it's not stock. Unfortunately it's back to the old grind at school and I wont be home until spring break, which is another two weeks . I will definitely put this at the top of my to do list though, thanks!
« Previous Thread
Next Thread »
| Search tags for this page |
2003 ninja zx6r runs loud possible ticking,kawasaki ticking noise after warm up synthetic,kawasaki versys engine noise,kawasaki zx11 making a knocking noise in the engine,knocking sound in 2010 klr engine on startup when cold,motor noise zx14,my kawasaki z1000 is making a ticking noise,my zx6r is making a knocking noise when i rev it up,ninja 1000 chain noise,ticking noise from right side of engine on a 2002 kawasaki ninja zx6r,what makes the ticking sound on the right front side of a kawasaki 14,zx14 making ticking noise
Click on a term to search for related topics.
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| Engine Clicking Noise | Sobe636 | ZX-6R | 1 | 03-22-2011 07:12 PM |
| Strange engine noise? | Darriczx12r | ZX-12R | 15 | 02-15-2006 07:26 PM |
| Engine noise @ 4000 rpm in my 2003,does someone know why? | zx-12rrider | ZX-12R | 17 | 01-22-2004 06:26 AM |
| Engine Noise | Blue9r | ZX-9R | 12 | 07-21-2003 03:09 PM |
| Noise when starting cold engine? | HappyCamper | ZX-12R | 11 | 09-15-2002 01:51 PM |
Linear Mode
