Kawasaki Forums
Go Back   Kawasaki World > Kawasaki Motorcycles > ZX-12R
Old 08-13-2002, 12:13 AM   #181
MarkPMB's Avatar
Theres a pic at the top of page 9 of the inside of the stator
2002 Pearl Mystic Bullet
 Remove Advertisements
Old 08-13-2002, 02:18 AM   #182
Add me to the list. Mine sprung a leak a couple of weeks ago and I didn't know what it was until I saw this thread. (Once again you guys are all over it! I love this site!) My plug was also 1/3 full of oil. I drained it out and wiped clean hoping it was just some dialectric jelly from the factory that had liquified from the summer heat and hot tempered 12. I was dissappointed to again see the oil dripping on my hugger/chain guard after my next ride of about an hour.
Okay, now I'm worried. Time to call the dealer. By the way this happened with 7k on the clock.
Old 08-13-2002, 12:59 PM   #183
Okay, I just finished replacing my generator cover. When I put the coil and wires into the new cover, here is what I found:
There are ~4 white wires that are not used in the cover. Their ends are covered with a black cloth tape. Due to their being in the cover the tape does not seal the ends from the rest of the case, instead the tape acts as a little tunnel directly to the exposed wires inside.
These wires are in the top half of the case but obviously oil does get in there. This is motor oil we're talking about here, not some grease or anything else.
Thus the oil does infact travel up the wires on the inside, not in the wire loom cover. I currently do not have the problem you guys are describing, though I can very easily see how I might in the future.
Incidentally, my bike is a 2002 model. Hope this helps to explain what you are finding.
Old 08-13-2002, 03:27 PM   #184
I have an 02 model and it has 6,000 miles on it. I am running Mobil 1 and I use the 12 to get me to and from work mostly. Only a couple of first gear power weelies and no high speed runs and I too have the small electrical connector addressed here leaking oil. I didn't have to pull it apart to notice it, as it has a motor oil pond on top of the connector. How often does Kawasaki recommend changing the oil in this connector? I have not changed the oil in this connector since the bike was new? This better not void my warranty as my manual has nothing about changing the oil in the connector. LOL!
I am calling my dealer tomorrow.
Thanks a bunch guys/gals.
Elbo
Old 08-14-2002, 01:09 AM   #185
MarkPMB's Avatar
Elbo, thats too funny <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/laugh.gif ALT=":lol"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/laugh.gif ALT=":lol"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/laugh.gif ALT=":lol">
Official BAM Club Member
Old 08-14-2002, 10:16 AM   #186
I Ride: CBR900RR, CR500R, 350 S2A
I Race: CR500R
Please see my post for the solution for this problem.
Regards
Ted
Old 08-14-2002, 12:03 PM   #187
MarkPMB's Avatar
Here's a link to Ted's thread........
One Possible Solution
Old 08-19-2002, 12:38 AM   #188
MarkPMB's Avatar
Here's Ted's thread in full, Im afraid it will drop off the board if I do not copy here.......
Author Comment
Ted Edwards
Expert
(8/14/02 1:56:05 pm)
Reply Possible solution to oil in connector problem
Guys,
This is for the guys that are out of warranty and can't get a replacement from Kawasaki.
Having thought long and hard about this very unusual problem, I think I may have come up with a viable solution.
Those in the aviation industry will be fully aware of what I am talking about, basically I would be inserting a "Plug break" in series with the wires that are allowing the oil to travel through them.
This sounds drastic, but please read the whole post before you make a decision.
Basically, you cut your wires somewhere just above the generator casing and before the frame gets in the way, I guess about 4 to 8 inches away from the generator casing.
You then get a plug and socket with the requistite number of pins, preferably an aircraft spec or something similar from a radio shack or whatever.
Some names as follows, Plessey, Hellerman Deusch, Cannon. The important thing is that they must be SOLDER type pins and sockets, I don't think crimp type will do.
You then "tin" the wire ends, (basically, bare a part of the inner wire, heat the wire and apply some solder to meltonto the wires. It helps if you put a slight twist on the wires to keep it tight and easier to apply the solder to) fill the male and female pin sockets with solder. Heat the pin and insert the bare "Tinned"wire into the socket. This should seal the wire end into the socket of the male or female pin. You can then "lightly" apply some glue/varnish etc over the end of the plastic insulation on the wire to seal it against the socket end of the pin.
DO NOT put the glue on the whole pin as it will insulate the connection.
Using the supplied insertion tool assemble the pins into the plug/socket.
Aircraft spec plugs and sockets are hermetically sealed to prevent moisture ingress, therefore it will be difficult for any oil to escape. They are also generally easy to do and undo (half twist or screw together)
The end results are as follows;
1) You have sealed the ends of the wires at a point just above the casing by soldering the wires and inserting them inside a pin. Therefore there is nowhere for the oil to go as you have disconnected the internal path through the wires.
2) You have sealed the plastic insulation to the pin.
3) You have sealed the pins inside a hermetically sealed plug/socket (connector).
4) You also have easy access to see if you have any problems with the repair.
5) You can also gain access to carry out any electrical testing without taking the seat unit apart.
5) It will also be a damn sight less expensive than replacing the generator. (Which could conceivable leak in the future).
6) You can also for "super safety" put in insulative "putty" or potting compound to further seal the connector.
OK Guys, the pain in my head has now gone away!! By the way, my bike is 7,000 miles and dry! (Faster 00 silver)
Sorry it was so long!
Anyone got any other ideas?
Regards
Ted
VinnieZX12R
Expert
(8/14/02 6:02:54 pm)
Reply Re: Possible solution to oil in connector problem
Not a bad idea Ted! Along those same lines, wonder if you could just cut a half inch of insulation off each wire, seal the wires with solder as you suggested, then cover the uninsulated areas with the glue/varnish? Just a thought.
"Take two beers and call me in the morning"
ZXLNT
Street Pro
(8/14/02 6:08:40 pm)
That might be a damn good idea. U have to take the freaking motor mount bolt space out anyway to get the fucking wiring harness of the bike. Major pain in the ass...
It's True The Way I Feel
Promised By Your Face
The Sound Of Your Voice
Painted On My Memories
Even If Your Not With Me
I'm With You
Ted Edwards
Expert
(8/15/02 2:56:58 pm)
Vinnie,
That might just do the trick if you are careful to ensure that the solder has penetrated ALL the strands of the wire. Would also be cheaper than buying a plug/socket! Nice one!
Any more news on your possible trip over the pond?
Regards
Ted
VinnieZX12R
Expert
(8/15/02 4:37:09 pm)
Still waiting to hear back from some contacts in London. I'm really hoping I get the chance, I'd love to visit London! I will try to touch base with them tomorrow, so hopefully I'll know something. I'll definitely let you know when I find out for sure.
Ted Edwards
Expert
(8/16/02 9:45:05 am)
OK Vinnie,
Regards
Ted
Old 08-20-2002, 09:45 AM   #189
JadeGreenZX12R's Avatar
Ok, so has anybody tried VinnieZX12R's suggested method of preventing the oil from traveling up the wires? I'd like to hear a few success stories before "novice me" goes cutting into the wires of my charging system!
Old 08-20-2002, 12:45 PM   #190
MarkPMB's Avatar
Roy (Slver12) and I have solutions to ours. The local dealer contacted Kawasaki, and they are replacing ours completely. I will drop mine off probally next week to have the warranty work performed.
Old 08-20-2002, 02:51 PM   #191
1reddawg12r's Avatar
okay fella's,i tried the RTV fix on my 12 at the beggining of this thread, before i went up to VIR thinking it would work...WELL IT DID NOT WORK...so i guess i will try TEDS fix next..it sounds more of a solid fix than the RTV fix..i had a feeling it would not work but i figured i would give it the old reddawg<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/embarassed.gif ALT=":o"> try..i will keep you posted..later...reddawg<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/embarassed.gif ALT=":o">
Old 08-24-2002, 06:15 AM   #192
MarkPMB's Avatar
<blockquote>Quote:<hr> Author Comment
EPSTEIN
Street Pro
(8/24/02 8:42:49 am)
Reply ANOTHER OIL LEAK In Harness
OK It happened again.......less than 1000 miles since repair......and yes my connector is FILLED with oil again....When we met Todd and stopped for lunch I asked him if he had checked his connector...he said no so I showed him the plug on mine .....a lil voice said "Pull It LUKE...Feel The Force" and F*&K it was filled with oil ....AGAIN.......New stator New Harness ...and i know its new cause the dealer (who I know personally) replaced it and saved my old part.......Dunno Any suggestions???..Brian
<hr></blockquote>
Old 08-25-2002, 01:25 PM   #193
Posts: n/a
I too have experienced this oil leak....I ahve yet to have an elecrical problem caused by it, but the harness was full of oil...enough where I could pour it out. I have conacted kawasaki about it, and as of yet have had no reply. The oil is not seeping through the wire bundle, but actually through the wires themselves. I discovered this by finding a hole in the bundle further up the line where another wire is coming out and finding that it was completely dry. I have never before seen anything like this. The dealer seemed stumped on how this could happen(big surprise there) But I also know others who have experienced this problem and had electrical problems because of it. Guess I will wait and see what Kawasaki has to say about it (if anything)
Old 08-28-2002, 02:24 AM   #194
I called my dealer yesterday and told them I'm bringing it in on Friday because "we" need to get this fixed. He's calling Kawasaki to see what he needs to do to warranty the work. These guys are friends of mine so we'll see how Kawasaki plays it. I'll let you know what happens. I also printed out much of this thread for the dealer so he can forward it onto Kawi if neccesary. They need to know we are having this problem and that "they" ned to fix it before one catches fire.
Old 08-28-2002, 04:58 AM   #195
I feel like I am being left out... I didnt find any oil
yet.
2000 6k+ miles
Never Ride Faster Than Your Guardian Angel Can Fly!!</p>
Old 08-30-2002, 01:24 PM   #196
I Ride: 2003 Z1K
I Race: 2003 Z1K
Cross your fingers.
Hello, My name is OutsiderZX12R, and I am a ZX-12R.org addict.</p>
Old 09-01-2002, 12:01 PM   #197
I have dealt with this problem for 2 years now! I figured it was something you had to live with! 00-green, and 00-black(used to be red)....every time I have the seat off, I unplug the connector and route it down low and let it drain for about 20 minutes....pita....is KWAK gonna' take care of this????
Old 09-02-2002, 08:36 AM   #198
I Ride: 2003 Z1K
I Race: 2003 Z1K
"Is KWAK going to take care of this?" <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/roll.gif ALT=":rollin">
Old 09-03-2002, 08:38 PM   #199
The dealer in Pensacola Florida. (P.M.S.) Claims they contacted Kawasaki and followed their instructions. They replace the alternator cover gasket and resealed the wiring harness. A week later and I don't have any oil dripping off of the conector but when opening up the conector I found it full of oil. I don't know if this is just residue from the problem before or not. We shall see.
Anybody want to put bets on that fixing the problem?
Now 2weeks after cleaning out the conector and just a little bit of oil in conector when I took it apart. Not enough to poor any out. Looks like maybe it is fixed for now.
</p>Edited by: <A HREF=http://pub56.ezboard.com/uelboman.showPublicProfile?language=EN>Elboman</A> at: 9/15/02 4:46:42 pm
Old 09-04-2002, 08:32 PM   #200
I Ride: 2003 Z1K
I Race: 2003 Z1K
I'm betting it won't. I did that when I changed stator covers. Still leaks.
Old 09-05-2002, 11:16 AM   #201
Kawi is warrantying my repairs on my '01 which is far out of its' original warranty. I spoke with the shop manager and explained the problems others have had with simply replacing the loop and he said they would fix it all the way so it won't occur again. Made my day. Can't wait to get the beast back. I like my new R1 but I love my 12.
Old 09-06-2002, 02:34 PM   #202
MarkPMB's Avatar
My dealer ordered the parts for my 02 today. Going to replace the stator and wiring assembly. The mechanic thought I was joking about it. I assured him I was serious.
We pulled my seat off and it was obvious. My connector, and the wiring harness in both directions was covered in oil.
I told him before he pulled the connector apart to get a few rags. He said "really?" Yep, we poured oil out of mine, on both sides. They claim they have never seen anything like that. I said "really?" <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/laugh.gif ALT=":lol">
Mechanic cleaned my connectors real good, reassembled the bike, and we ordered some parts. I'll take it in next week for repairs.
Is that a Bam?
Old 09-09-2002, 05:02 PM   #203
Member
First off I'd like to say thanks for the very usefull information, I'm new to the site and have put it to the top of my list for zx12r sites. GREAT JOB! by EPSTEIN's reply it sounds like the warranty fix did not cure the problem. Am I understanding this correctly? If so, the great idea of ZXLNT in Ted Edwards thread on how to fix the problem is probably the best approach. This is where ZXLNT mentioned striping back some of the insulation on each of the wires and wicking solder into the bear wire and then reinsulating it. Just remember the wire will probably already have oil on it so you will want to use some electrical cleaner to clean the wire before soldering it.
what do ya think?? (and thanks again, great group)
Old 09-11-2002, 12:21 AM   #204
MarkPMB's Avatar
My 02 is at the dealer now to have repairs made.
I'll let you know if it is a successful surgery <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)">
Is that a Buell?
</p>Edited by: <A HREF=http://pub56.ezboard.com/umwrzx12.showPublicProfile?language=EN>mwrzx12</A>* at: 9/11/02 6:07:11 am
Old 09-13-2002, 10:01 AM   #205
Well, it looks like Kawi is using my bike as a case study to figure out what is happening here. They asked the dealer to send the stator, cover, gasket and wiring loop back as one unit so they can examine the whole assembly. Looks like they are going to replace the entire assembly under warranty but they aren't paying for for labor! I'll let you know how this turns out. Peace.
Old 09-15-2002, 01:09 PM   #206
Member
I just finished checking my Blue '02 and it is as dry as a bone inside the rear cowling. Not even the slightest residue of oil, only some road or brake dust. <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)">
I have 3500 km. on it, but I will check it everytime I do a oil change just to be on the safe side.
Old 09-15-2002, 03:39 PM   #207
Happy camper, Did you disconect and check inside the small conector on the left side under the front seat? That conector has a rubber O ring or seal to seal water out and it also works good for sealing the oil inside the conector keeping your cowling dry and hiding the problem.
Just a thought.
Old 09-16-2002, 08:33 AM   #208
Moderator
EPSTEIN's Avatar
spoke to my dealer again
Spoke to my dealer again and he stated just bring it back and they will replace the stator and harness yet again.........Now I had a very wierd experience ......I rode the bike for at least 30 miles.....and stopped ...and it was as dead as Elvis Presley.......jumped it ran it ...and didnt have that problem again.......hmmm scratch it as just a freak battery problem or is oil the culprit.......hmm shoudl I push for a new battery as well?....
Old 09-17-2002, 08:01 AM   #209
MarkPMB's Avatar
Going to pick the 12 up at lunch. We'll see it it stays leak free :?
Old 09-17-2002, 12:37 PM   #210
MarkPMB's Avatar
I have mine back. Seems ok right now, I'll keep a check on it...
Old 09-17-2002, 08:47 PM   #211
Add me to the list. Went on a 200 mile afternoon ride. Stopped for a late lunch. Dammit, I seen oil dripping on the swingarm. 7700 miles. Talked to my dealer, said bring it in tomorrow. And that they would call Kawi.
Old 09-18-2002, 05:36 PM   #212
Dealer called Kawi service. Told them to order a stator which comes with the harness and send my old one back in. They said they know they have a problem but are trying to figure it out.
Old 09-21-2002, 07:56 AM   #213
Member
Oil In Rear LHS 3 Pin Connector
:( Add me to the "Oil In 3 Pin connector" group. I have 34,000k's on my toy and there has never been a sign of oil around the offending area. I pulled the connector apart for piece of mind - BUMMER - there was about half a teaspoon on the inside of the 3 pin connector.
Old 09-23-2002, 08:14 PM   #214
Took my 01 pearl white 12 to the dealer today here in Tx. They had never heard of this problem. I gave them some threads to read and the web to look at. Wish me luck.
Old 09-24-2002, 04:58 PM   #215
I Ride: 2003 Z1K
I Race: 2003 Z1K
Sounds like the dealers in Central Kansas. Two of them haven't heard of it, so they say. :shock:
Old 10-04-2002, 06:10 AM   #216
i guess i better check mine. :x
Old 10-04-2002, 10:15 AM   #217
I Ride: 2003 Z1K
I Race: 2003 Z1K
You haven't looked yet :?: :shock:
Old 10-04-2002, 10:19 AM   #218
MarkPMB's Avatar
G to busy being a ripped green ho :P :P :P
Old 10-10-2002, 05:52 AM   #219
:P
Old 10-10-2002, 12:05 PM   #220
I Ride: 2003 Z1K
I Race: 2003 Z1K
I understand now!
Old 10-11-2002, 09:59 AM   #221
relaxxxxx man... its cool.... :)
Old 10-11-2002, 10:20 AM   #222
Hmmm...
I've had the 12 back for a couple of weeks now and have put about 500 miles on her since parts were replaced with no sign of oil in narness yet. Kawi picked up the whole she-bang, parts labor and all even though my warranty expired in March. I hope they treat everyone else the same. Good luck. I'll post here if the problem returns. Peace.
Old 11-11-2002, 06:52 PM   #223
oil leak
is that only on the 2002 model
Old 12-23-2002, 05:58 AM   #224
MarkPMB's Avatar
This is a recall. Contact Kawasaki for more information.
I have not received my recall in the mail, but it is on the way.
Old 12-24-2002, 10:04 AM   #225
Elbo
I now have 11,000 miles on said bike. I took the connector apart and only a small trace of oil was noticabel inside the conector. Not even enough to poor out, unlike before. I believe it was a small enough amount to have been left over in the wiring harnes from before fix was preformed at 6,000 miles. So now I am a happy camper.
The reciept says that the parts used was a "generator cover gasket" and labor was "remove alternator and reseal"
Looks like it worked.
Old 01-15-2003, 01:27 AM   #226
Alternator Oil Leak Recall
G'day,
Just recieved my recall notice via snail mail. Dark down here now so I'll check it out on the morrow. Let ya know what I find.
Old 12-08-2008, 04:41 PM   #227
Member
scoutmanii74's Avatar
stator oil
My battery went dead on me the other day and I was checking it out. I took the connecter apart for my stator and it was full of oil. And now I'm not getting any voltage from my stator to charge my battery. but my lights and stuff r working. Because I read about people losing there lights. I can put it on the charger and then ride it for a bit and shut it off and it is dead. does that sound like the cause and problem. I'm glad to see someong doing more checking on it. I noticed the oil there before and couldn't find anything out.
Old 12-09-2008, 04:00 AM   #228
Kawasabi's Avatar
Old 06-29-2009, 09:38 PM   #229
Could it be that the oil that is wicked up through the harness is creating resistance in that harness? Cuz I've done the soldering fix and removed the connectors that fill with oil. I'm still getting dead battery problems and the wires I've soldered are now browning, they will eventually get brittle and fry. I was thinking of doing this.... Make the solder near or even in the stator casing to prevent the wicking of oil all the way to the tail section.Of course that would be done after a new stator, harness and rectifier/voltage regulator. Any thoughts?
Old 06-29-2009, 09:49 PM   #230
Or.... replace the wires themselves with solid copper wire. All the way from where they connect to the stator. There are only three wires coming from the stator right? https://www.regulatorrectifier.com/c...ges/21-216.jpg Because from what I've read the wicking of the oil into the wires is within the wire strands themselves, not the insulation.
Old 11-12-2009, 02:26 PM   #231
Member
spindian's Avatar
I Ride: 2003 ZX12r
I Race: 09 NISSAN SER SPEC V
yo, that problem you described about the mysterious oil will lead to one of the two regulator connectors becoming saturated in oil. this will lead to the connector becoming ONE connection! big problem! pull them apart and inspect.
i know this because i just removed the connector, it had melted together causing a serious charging issue...
Old 11-13-2009, 09:10 AM   #232
SilkyWilson's Avatar
I Ride: The Wife, 02 RC51, 02 GSXR600 08 KTM 450excr
ROFLMAO talk about reviving a dead thread.. this is from 2002.. I believe there is a recall on it and the dealers fix is super glue.. member's here have found multiple better ways to rectify the situation.
