Having problems with overheating!!!!help - Kawasaki Forum :: KawasakiWorld.com
post #1 of 11 Old 06-26-2009, 11:27 PM Thread Starter
Send a message via Yahoo to Down2Ryde
Kaw FAM,
I just flushed my coolant and now its running hot while in traffic. to the point where the coolant if bubbling in the resevoir tank. ANY ADVICE KAW FAM will be greatly appreciate. Could it be the thermostat sticking???????
Lamont
Down2Ryde is offline
post #2 of 11 Old 06-27-2009, 06:22 AM
Blade_69's Avatar
Send a message via Yahoo to Blade_69
I've never changed my coolant myself, but I've heard others say that 1 - it could be the type of coolant you use, and 2 - you may need to "burb" the system because air is trapped in there somewhere. I "added" some 50/50 to my system the first year I had my bike cuz I noticed it was running hot and the coolant was low. Had the dealer flush it for me this year, and noticed that it runs hotter and the fan kicks on a lot. So I'm thinking of draining some of whatever the dealer put in and add some more 50/50. Anyway, do a quick search on burb and I'm sure you'll find it.
EDIT!! I'm pretty sure you mean "burp", or "burping the radiator", something like that... GO 200
~With great power comes great responsibility~
Blade_69 is offline
post #3 of 11 Old 06-28-2009, 05:45 PM Thread Starter
Thank you Kaw Fam...I will try this method and keep you posted....
post #4 of 11 Old 06-29-2009, 01:38 AM
Take it to a mech that you turst to check your system.
If everything looks ok have the head gasket checked and the head it self for cracks.Do not use any kid of radiator sealants and do not spend time changing parts like the thermostat if the temps are not normal.Check the head.
The cooling system is a tricky thing to mess with..
"In 1999 everyone laughed at the ZZR 1100.... well no one is laughing anymore.."
NUCLEON ST is offline
post #5 of 11 Old 06-29-2009, 08:06 AM
thekaz's Avatar
Originally Posted by Down2Ryde View Post
Kaw FAM,
Lamont
What exactly did you do when you say flushed my coolant ?
what brand and mix did you refill with ?
Did you forget something simple like rad cap not tight fan unplugged ?
Spell chequer is completely bustimicated
thekaz is offline
post #6 of 11 Old 06-29-2009, 11:00 AM
n52
n52's Avatar
I did this very simple and cheap I put up some pics soon.
From bikeland:
Its simple the are two wires on the thermal switch located on the left side of the radiator. You just tap into those two wires with a togle switch one leg of the switch on each wire. To test the method just put a jumper across the two wires and the fan will come on. I found that the cooling sytem its self is fine its the fans dont pull enough air through the radiator the rpm on the fan is to low.
n52 is offline
post #7 of 11 Old 06-29-2009, 11:42 AM
Moderator
Connman's Avatar
Sounds like there may be air trapped, I agree you probably need to burp it.
Don't forget the "Water Wetter", the stuff works wonders for hot running engines.
Go with 75% water, 25% glycol, and 1 ounce of water wetter per quart of water/glycol solution.
Guaranteed to run cooler.
Any twelve people who can't get themselves out of jury duty are not my peers.
Connman is offline
post #8 of 11 Old 06-30-2009, 01:14 AM
I allways suggest to switch off the engine when you know that you will be standing on a traffic light that will be red for a minuete or more and on long descents.
In addition with a fan switch that opens earlier it is a good combination to keep your bike from running hot less.
post #9 of 11 Old 06-30-2009, 10:17 AM
XPLORZ's Avatar
Mine developed an overheating issue after a highside a few years back. I chased the problem for six months thinking the fan switch wasn't working because it would start to boil right before the fan came on. So I wired up a manual fan switch and that helped some. Then one day when I had the plastics off I opened the radiator cap to check the coolant level again. It didn't look too bad. Then with the cap still off I gave the radiator hose a good squeeze. A huge air bubble came belching out. I squeezed a few more times until no more air bubbles came out, repeating the proceedure on all hoses i could reach. I topped off the coolant, buttoned 'er up and it has not overheated again to this day.
So my bet is air in the coolant system and the "burp" is what it needs.
I should have thought of it much sooner as it is a common problem on snowmobiles too.
09 BMW R1200GS Adv
06 Suzuki DR650
02 Kawasaki ZX12R
XPLORZ is offline
post #10 of 11 Old 06-30-2009, 10:47 AM
Yes!Parts like thermostat and switch are unlikely to fail.Most of the time burping,cracks,leaks are usualy the problem..
post #11 of 11 Old 07-02-2009, 05:50 AM Thread Starter
Thanks Kaw fam I burped it yesterday and she is running sweet!!! Again i appreciate all input.....
Human Verification
overheating problem.... ZX12Hef ZX-12R 32 01-12-2007 12:03 PM
Overheating Tee2026 ZX-12R 13 04-12-2004 06:12 PM
Overheating modoc ZX-12R 22 07-02-2003 12:37 AM
Overheating Issues ZX-12R 10 05-03-2003 10:04 PM
Overheating problem.... thorgoft ZX-12R 14 03-19-2003 01:36 PM
