not enough oil in clutch pack? *how to fix* - Page 3 - Kawasaki Forum :: KawasakiWorld.com
post #31 of 59 Old 02-14-2012, 09:45 AM Thread Starter
KZScott's Avatar
any tests done with a launch and shifting up thru the gears? that might be a little too much oil? hard to tell without a good simulated drag run
KZScott is offline
post #32 of 59 Old 02-14-2012, 07:26 PM
Hibs's Avatar
Have not yet, been snowing here.
Too much oil, cause it to slip?
Hibs is offline
post #33 of 59 Old 02-14-2012, 09:02 PM Thread Starter
KZScott's Avatar
i dont know if it would slip(maybe?), but i think it would add rotating weight and maybe rob a psi or so from other places until the pump overcame the relief valve pressure.
KZScott is offline
post #34 of 59 Old 02-15-2012, 02:02 AM
Hibs's Avatar
So, how do you tell??
Hibs is offline
post #35 of 59 Old 02-15-2012, 04:26 AM Thread Starter
KZScott's Avatar
go to the drag strip, make a pass, drive back to pits, pull the cover.
KZScott is offline
post #36 of 59 Old 02-15-2012, 06:19 AM
Hibs's Avatar
OK, but what does "to much" oil look like? And what does "just right" look like?
Hibs is offline
post #37 of 59 Old 02-15-2012, 04:18 PM Thread Starter
KZScott's Avatar
i dont have any pics. they should be wet, but not dripping IMO. there will be a little in the hub. once you stop burning up plates thats enough lol
KZScott is offline
post #38 of 59 Old 03-03-2012, 10:02 AM
12r
Is there something different with A model and B model bikes that would make this unnecessary on say a 2003 B2? This issue is mentioned as a Gen 1 bike issue. I dont see any difference in the clutch rod or sleeve bushing, only the clutch hub part number is different from 2000 to 2003 (but physically I dont see any difference wiht an 03 set up and the pics of in this thread that would change anything. Outside of, IF I have a dry clutch this would be beneficial...
12r is offline
post #39 of 59 Old 03-10-2012, 02:38 PM Thread Starter
KZScott's Avatar
Originally Posted by 12r View Post
Is there something different with A model and B model bikes that would make this unnecessary on say a 2003 B2? .
there are differences, but the answer is NO
KZScott is offline
post #40 of 59 Old 09-14-2012, 09:59 AM
irki's Avatar
HI All
KZScott, what is the difference between stock hub and Muzzy's? Please correct me if I am wrong, Muzzy's hub is drilled through in these two little wholes?
Or does it have any more differences?
I have ZX12 2002, bought Brock's clutch springs and now I am wondering about this mod.
I have bought this hub (stock from crashed bike) and I can't see any differences at first glance.
irki is offline
post #41 of 59 Old 09-17-2012, 05:39 AM Thread Starter
KZScott's Avatar
Muzzy starts with an oem hub and does a similar process
KZScott is offline
post #42 of 59 Old 09-17-2012, 11:02 AM
irki's Avatar
Thanks for answer KZScott, but I still dont know what is exactly the difference betwen this hubs. I want to know this because I am going to tune my ZX to around 210HP, and the clutch is very important part in this process - in my opinion.
So what about the wholes? Maybe general dimentions are some different? Are you able to make mesures of it.
and for last please confirm, this same modyfications are you made in 2002 and Younger ZX12?
irki is offline
post #43 of 59 Old 09-17-2012, 08:31 PM Thread Starter
KZScott's Avatar
look at the pics on the first page, all the info is there as far as spacing and hole size. same process for all yrs
KZScott is offline
post #44 of 59 Old 09-17-2012, 08:48 PM
Hibs's Avatar
Originally Posted by Hibs View Post
Here's my pusher...
I'm right at an 1/8" where I grinded it down. I pulled my clutch pack last night, the first couple fibers had oil on them, and there was some oil in the bottom of the hub, but the majority of the fibers were dry. I think I'm going to grind the pusher more towards 1/4" and see if that helps.
IMO i would try a little more to the right first, its not quite to the wear point, so it may not be getting the full amount if the lever isnt all the way to the bar. I would bring it to the edge of the wear point. im not really used to the stock ones anymore lol, been dealing with the MTC piece for so long now, you just have to do the tip of those
Here's where I went last night... assembled it all together, fired it up, going for a test ride this afternoon....
If i remember correctly, this ended up being just under 1/4 wide that was ground down. I made about 30-40 passes at the strip last year, no issues. Over 2000 miles on the street, no issues. Still on the OEM clutch which has almost 17k miles on it. No decrease in power or ET from my best guess. I had drag raced before and after, but there was other power increasing mods added, and also a drastic change in elevation, so it's hard to say exactly.
Hibs is offline
post #45 of 59 Old 09-18-2012, 11:06 PM
irki's Avatar
Guys Thanks for help. from begening I know what to do with the pusher, but I am asking you about the hub. As I mentioned previously, I have bought this part and I cant see the difference between my (original from other bike) and this one below. All what I am asking you regarding this item.
I read all pages of this topic, as I understand - in all your cases you "fixed" the pusher not not the hub. I have posibilities to made this hub (my friends working in kind of factory)
KZScott you drew the arrow (to the hole). I am asking you about the holes, are they drilled through? Because on my pusher they are drilled in 4mm of hub
irki is offline
  Kawasaki Forum :: KawasakiWorld.com > Kawasaki World > Racing
Human Verification
ZX12r Muzzy billet basket & modified hub with clutch pack meangreen Classifieds 11 08-23-2013 08:43 PM
F/S stock '03 clutch pack k9rockydog Classifieds 1 05-13-2011 01:55 PM
Pack it up and GO!!!! wylde ZX-12R 12 11-03-2010 10:22 AM
Vesrah clutch pack for the 12? lie2me ZX-12R 31 07-04-2006 12:24 PM
When to pack??? ynot ZX-12R 24 07-29-2005 02:32 AM
