| | #1 |
| parts---help needed
I figured some of you on here use an online parts store/source to get replacement parts, and I'm not having any luck on ebay (parts I need aren't listed). trying to find, reasonably, a front brake lever and air filter cage for my 2001 honda cr80rb. help appreciated!! | |
| | #2 |
piglet - Bike Bandit & Ron Ayers are good online sources if you don't already use them... Bike Bandit: 2001 Honda CR80RB EXPERT OEM Parts, 2001 Honda CR80RB EXPERT OEM Motorcycle Parts - BikeBandit.com Brake lever- LEVER, R. HANDLEBAR 2346-001 $16.82 Not sure what you mean by "air filter cage", but here's my best guess(es) of what you're talking about: Air filter cage(?)- HOUSING *NH220* (SMOKE GRAY) 229316-001 $88.15 BASE, ELEMENT 229749-001 $15.58 Hope this helps! | |
| | #3 |
you're awesome!! you nailed the air filter thing right on the nose!!! thanks a bunch for the sources!!!
| | #4 |
No problem!! | |
| | #5 |
You know the difference between ass kissing and brown nosing? :-)
| | #6 |
| | #7 |
got the cage!! bought the brake lever from cycle gear, since they had it in when we went to get something else! cage should be here by wednesday!!! thanks for the help go!! | |
| | #8 |
De nada... ![]() | |
| | #9 |
Depth perception. :-)
Linear Mode
