Klx300 02. First engine rebuild - Kawasaki Forum :: KawasakiWorld.com
View Poll Results: Bearing sealed side face?
Seal side outward (feeding the input shaft but blocking oil pressure from entering the bearing 0 0%
Seal side inward (feeding oil pressure to the input shaft and the bearing) 1 50.00%
Dont know good question 1 50.00%
Its complicated 0 0%
Voters: 2. You may not vote on this poll
post #1 of 2 Old 02-28-2015, 06:05 PM Thread Starter
I bought a junk 02 klx300r. .. One problem led to another to another to another. So far ive got the head resleaved,piston fittied, rings filed, new valve rod seals, valves seated, shims replaced, professionally cleaned inspected and even ported my intake a little.. So the topends done.
I'm reassebling the bottom end and installing new bearings and seals throughout the case. Ive run into a thinker and ive installed this bearing the way it was removed(which was sealed side in) but im second guessung myself bc its oil fed and mayby This bearing needs to be oil fed? I want to be sure before i continue.. Any thoughts?
HulkSmash is offline
post #2 of 2 Old 03-01-2015, 07:26 AM
jhinderliter's Avatar
All I could do is speculate , never been inside one ...
Try here
ThumperTalk
jhinderliter is offline
  Kawasaki Forum :: KawasakiWorld.com > Kawasaki Motorcycles > KLR KLX
Human Verification
Engine Rebuild Elboriqua ZX-11 20 10-21-2014 10:14 PM
going in for rebuild 00A1ZX12R ZX-12R 3 03-30-2014 02:04 PM
Engine Rebuild witchdoctor ZX-12R 7 07-31-2011 01:39 PM
85' GPZ 900 Engine Rebuild Question _12R_Rider_ ZX-9R 5 03-13-2011 11:23 AM
The rebuild is done zx996 ZX-14 22 12-19-2010 07:40 AM
