When Will My Motorcycle Battery Die? - Kawasaki Forum :: KawasakiWorld.com
post #1 of 1 Old 02-22-2017, 11:50 AM Thread Starter
It depends where the bike lives: Hot and cold climates are both harder on batteries than temperate climes, and bikes that get ridden regularly are easier on batteries than ones that sit for months – though a good battery tender with a float feature negates much of that. In fact, I was bragging about the Shorai lithium-iron battery in my bike not long ago, which must be seven years old now and has never seen a charger, when my friend Jim said big deal, the original equipment sealed AGM battery in his VFR lasted 9.5 years, and his 21-year old Ducati is only on its second battery. So, sealed batteries can last a long time especially if you’re OCD about maintenance.
According to several sources including BatteryStuff.com, though, your 12.3-volt reading means your battery may be on its way to Nirvana; a fully charged one should read 12.7 volts or above. Since you like to play with your voltmeter, there are instructions to “stress test” your battery at the same page, along with a lot of other battery tidbits that will let you know for certain if it’s time to replace.
Send your moto questions to AskMOAnything@motorcycle.com. If we don’t know the answer, we know who does, and if they don’t know we’ll make up something reasonable-sounding. What do you want for free?
Read more about When Will My Motorcycle Battery Die? at Motorcycle.com.
Motorcycle.com is offline
  Kawasaki Forum :: KawasakiWorld.com > Kawasaki World > General Discussion
Human Verification
Stator Burnt Again!! Duck00 ZX-12R 15 12-05-2016 05:12 PM
Register an H2R? Connman Ninja H2 26 11-02-2016 07:38 PM
Dead Battery shrek 1 ZX-12R 12 08-11-2016 10:09 AM
Battery Tender DinoDanny ZX-12R 15 07-26-2016 06:16 AM
