Idle issue PLEASE HELP - Kawasaki Forum :: KawasakiWorld.com
post #1 of 3 Old 07-28-2014, 08:44 AM Thread Starter
Hi my name is logan I just bought a 94 ninja 500 Saturday for my birthday. I replaced the battery, oill, and spark plugs. I also cleaned the carbs. It stars good but will not idle on its own I will let go of the throttle and it will die almost instantly. It will idle at 3000 for awhile then die down again. I tried adjusting the throttle screw but that doesn't seem to work either. Please help me get my present working thank you
Motoreacion152 is offline
post #2 of 3 Old 07-28-2014, 08:58 AM
OutsiderZX12R's Avatar
Send a message via Yahoo to OutsiderZX12R
Sounds like the pilot jets in the carburetors could be plugged.
I hate stupid people.
OutsiderZX12R is offline
post #3 of 3 Old 07-31-2014, 12:53 PM
Thumbs up
When you say "cleaned the carbs" can you detail what you mean? Do you mean dump the gas out of the bowls or do you mean completely disassemble and rebuild?
What you are describing is textbook for old gas sitting in the carbs and starting to return to its prior carbon form (ergo it's beyond shot). When this happens it will gum up the jets and start to distribute a white flaky residue over everything touching it.
Also, how old is the gas in the tank? Old gas can cause this type of issue all day long as can water in the gas.
“There is no room in this country for hyphenated Americanism.”
Theodore Roosevelt
(1858-1919)
IWasBlitz is offline
  Kawasaki Forum :: KawasakiWorld.com > Kawasaki Motorcycles > 250R 500R
Human Verification
ZX-14 won't idle BillT ZX-14 3 04-03-2012 10:07 AM
How do I adjust my idle? imkindafkedup ZX-12R 22 06-20-2007 10:45 PM
my 12 will not idle pete1096 ZX-12R 7 05-09-2006 08:56 PM
Idle help cdpratt69 ZX-12R 10 09-20-2005 12:14 PM
idle hunt ZX-12R 6 08-26-2002 03:28 AM
